Baggin an I-beam ranger
ne25 avatar
ne25
got the basics air management kit brackets trans x-member radius arm x-member want to lay frame on 17x9 cobras are there any surprises i need to know about. also where can i get a fuel cell that my gauge will work with and holds plenty of fuel i drive it daily. lastly can some explain why i need to and what goes into notching my i-beams i got the belltech ones and i want to keep them
msturg avatar
msturg
normally i believe you notch the frame for the beams not the beams for the frame.
east*coast*nomad avatar
east*coast*nomad
most poeple notch the frame for the tie rods i believe dont hold me to it.
fuller avatar
fuller
if u have the round beams yer good to go, otherwise i think u have to trim the xmember for clearance
Lo Range avatar
Lo Range
you have to notch the belltech beams due to the fact there to bulky. but ya in order to lay out and the lower mount to fit properly ya you have to notch the beam and the frame. save your self a huge headach and just get a set of djm dream beams.
swayed and layed avatar
swayed and layed
like LO said you need to notch the beams cause they will hit the oil pan and stop you from lying. Make sure if you do notch the beam you need to reinforce it very well(since that holds most of the front load). You will also need to notch the frame on the passenger side for the tierod so that you can lay. What kind of brackets did you get for the front?? I have suicidedoors, but they arent that great how they are angled(I love everything Jason makes just not the brackets. I recommend making your own brackets. Everything else should be straight. Your wheel wells can stay i believe with 17's. Good luck
THE LOW RANGER avatar
THE LOW RANGER
CHECK MINE OUT
87 range avatar
87 range
iv got an 87 ranger and im working on the bag setup right now, im getting all my parts from whynotfab.com i just got the notch in chack out the pics my 87 ranger bag project
BillyHo avatar
BillyHo
I bagged my 88 and used DJM and Alter Images bag mounts, along with the relocator and made my own tranny mount. (The one I've seen hang below the frame rails.) But we had to notch the frame for the tie rods and also for more clearance for the I-beams near the oil pan.
