Ride Height
Ride Height
slamdB
Shat height do guys "set" your truck at when bagggin' and linkin'? Otherwise what is a good ride height for a 2" bodydropped truck?
Later
LaydRado368
just make sure that you have enough lift in the front to clear the tires. thats good enough. my ride height is just enough not to lose my roll pan.
whynotfab's avatar
whynotfab
When im crusing a pretty good distance and know i wont be turning every 5 seconds, I drop the front low.. but through town, turning and all.. I ride with the fenderwell just a little below the tire, so I can turn.. just not make full Uturns..lol. as for the back, id just set it where the bag is half way extended.. so you have a good ride, but you can always ride lower anyway.. wouldnt hurt anything if the link is setup correctly.
LaydRado368
another thing, just make sure whatever ride height that you choose, that the links are parallel to the truck at ride height, that will achieve the best ride.
lowdyme's avatar
lowdyme
as low as possible most of the time about a inch or two from the ground just watch out for man holes and rail road crassings
s10
last post by baha +1y
