4- Link & Hittin Side
F
FrameLayN88
I was asked a question by a friend of mine, that I could not answer with out being 100% sure!
Do you have to have the super ball joints to be able to hit side - side with a forward 4- Link? I have heared people talking about how it puts alot of stress on the 4-Link brackets.What is your opion?
Thanks for the help in advance!FrameLayN88Isuzu
sadisticiron's avatar
sadisticiron
yeah need heims to hit side with out them a four link built right with a strong crossmembers wont pivot and puts a-lot of stress on brackets,bushings,etc
slamdB
In a triangulated 4-link how does altering the angle of the upper bars in relation the the lower bars affect side hittin'?
F
FrameLayN88
If you don't have the super pivots it will bined. I have never heared of some one altering the angle of the upper or lower bars to hit sides.
FrameLayN88
Isuzu
Low_SST's avatar
Low_SST
yea it will effect lateral axle travel and the side hitting of your tire whacking your fenders around turns.
east*coast*nomad's avatar
east*coast*nomad
yea i have heims and a rev 4 link i can hit a good side
periportfd
Do you have to have the super ball joints to be able to hit side - side......No you don't NEED them but they help alot.
F
FrameLayN88
Andy Would you mined to explain what you mean by they help?
Thanks
FrameLayN88
Isuzu
periportfd
The link's movement is to twist as the axle twists side to side. If you have a regular bushing it will flex by deforming the bushing material and then return to its original shape when you straighten the axle out. This isn't the intended use of a bushing. It's main job is to allow movement in one plane (up and down along one axis. Urethane further helps to keep it on this path by holding the sleeve even tighter). A superpivot, pivots much like a rod end, many angles of unrestricted movement. Thats why to answer your question directly, you don't NEED them but they will help reduce wear and tear on the joint and allow it to articulate more.
s10
last post by baha +1y
