fireing order for a chevy small block
cdndragrr
i need the fireing order for the distribtor cap anybody know or have a diagram they can post for my dumb ass
cdndragrr
i found the fireing order,now i need to know which is the number 1 point on the distributor
dysinger1
18436572, usually number 1 is at about 5 or 4 o clock on the distributor. just be sure you are on the compression stroke when you set it you dont want to be 180 out.
cdndragrr
whats the best way to make sure its on the compression stroke
MRCO
you can put #1 anywhere as far as where the distributors(rotor) facing.
i myself as dude above mentioned, is about 4-5 oclock, or pointing at cylinder #1.
if anyone cares, small block chev and big block chev firing orders are the same.
dysinger1
put your finger on the spark plug hole turn the motor over by hand if it pushes your finger away thats the one you want if it sucks it in keep rotating till pushes on it.
lower
put finger in the number one plug whole drivers side front of motor when you feel it blowing your finger out watch the harmonic balancer for the timing mark and bring it up tdc. then look at the rotor bug and it will be pointing directly at the number one plug. you may have to adjust timing to get it perfect if you are putting in a new distributor or if you just tore it all out and didnt touch the distributor and where it was set you will be at the number one plug
I
iamchris
"i found the fireing order,now i need to know which is the number 1 point on the distributor"
Would be where the rotor is pointing #1 cyl when it is on tdc and you go clockwise
