Yota 2.4L 22-RE I4 \  Electric Fan
Electric Fan
views 653
replies 1
following 2
slammedtoys   +1y
Those of you that switched to the electric fan... did you have to do any thing different when you removed the factory one other then put a washer in and put the nuts back up to the factory pully?? I did the swap yesterday and it seems like my belt is not on there stright anymore... do i need to add more washers since i only put one or did i miss a step?? I have a 22re and did a compleate removal of the fan and the fan clutch
mulisharider11x   +1y
i removed the stock fan shroud, took old fan and clutch off and replaced with a thick washer and nut, i didnt remove the pulley or belt durring the swap. there might have been a spacer behind the pulley... but i doubt it...
