Side molding
Side molding
LesserFord
If the side molding is just attached with adhesive what's the best way to remove it? Thanks
DedicatedCaprice
Use a heat gun "carefully" to heat up the glue and the molding should pull off( you may have to do a little area at a time)then clean up any left over glue with 3m adhesive remover.
jmn444's avatar
jmn444
^^^ that's the best bet, I've also used the plastic drywall mud scraper deals to pry them off GENTLY. I doubt you care, but odds are good that you'll mess up the paint on the moldings when you pull them off, so if you did need to re-use them try to pull them off as straight as possible. If the paint on them spiderwebs/cracks you'll need to strip them to get a good finish again...
Severed701's avatar
Severed701
a little fishing string will do the trick for taking them off if you dont have a molding removal tool , then u can use a 3m eraser wheel to take off the double stick tape thats left over...
LesserFord
Great thanks for the responses... where might I be able to pick up those 3M products? Paint supply stores?
bodydropped85's avatar
bodydropped85
yup fishin string and a 3m wheel, ive seen em at walmart, there the yellow ones.
BankruptRam's avatar
BankruptRam
Fishing String and the 3M Eraser Wheel. That wheel wont mess up your paint either, trust me, I tried!
LesserFord
Great thanks for the help
F
FloorVair
Just pull that bitch off, use your thumb to roll off the remaining adhesive, then use DX440 to clean off residue.
LesserFord
Think I'll have any discoloration? The truck has been garage kept for the last 5 years but before that it's anyone guess since it was purchased used.
