Air Ride Suspensions \  very odd ball joint problem
Air Ride Suspensions Q & A
views 79
replies 7
following 6
Texas Cadillac   +1y
well i have a 1967 caddy i was crusing it the oher night riding about 80psi up front 40 in the rear i heard a pop then the right side front tire started rubbin bad i pulled over and figured i had broke a ball joint well iget i back to my job and take a look and i see that the ball joint just seem tohve pulled out the spindle the ball joint is still intact with the nut on the end of it i cant figure this ut any help would be nice
Low_SST   +1y
mabey the nut had some play and was riding on the spindle and wore itself through.
TC29720   +1y
This is exactly why I hate press in ball joints. I never have trusted them
bagking   +1y
screw it just weld it in there is nothin a sawzaw and a welder cant fix
periportfd   +1y
The ball joint is completely intact with the nut still? You sure the spindle hole isn't split in the back?
lumbrjak472   +1y
is it the upper or lower ball joint? the uppers have a wierd brass eccentric thing that adjusts the camber that is pressed into the spindle. did you have a washer under the nut???
p.s. where in texas are you? get some pics up!
Texas Cadillac   +1y
i put a big washer on the bottom fixed it for now i am from galveston tx
lumbrjak472   +1y
damn i went to A&M in galveston for a year. drove my cad down there a couple of times from ft. worth. good luck with the repair.
