Run a Viair 380 at 24 volts?
lo4lyf
Can i run a Viair 380 at 24 volts? Will it fill faster? Will it last?
gmoyeshavedclean
I don't think you can you will burn it up,just add a yellow top, that way it will keep a constant 12volt on the compressors and not die out when engine rpm drops
forbidden's avatar
forbidden
Edited: 10/5/2005 6:44:58 PM by forbidden alero
They do not make a 24volt 380 series.. they do make one in the 450 series but you have to order it that way... its a different compressor the part number is 45048
s10
last post by baha +1y
