layn frame on 20 s on a 98++++ bd ranger
laynLowEdge
Ok guys heres the skinny i am bodydropping my truck the frame is off it and the new frame is on the ground. The bag cups arent in yet but evrything is cut i mean majorly> the uppers are raised 2 inches and im not running any aftermarket lowers and i still need 2 inches oh and the tierods arent hooked up yet either. SO how did yall get it done
BdyDrpdRanger
I had DJM's on mine and it layed but look where the backmount of the lower control arm is mounted. I had to notch that a little to get mine to lay. Plus I didn't raise my uppers 2 inches. I raised them a inch and moved them in 3/4 of a inch.
laynLowEdge
did you lay frame
laynLowEdge
i i notched that out also till the point to where if i notched anymore i would be cutting the frame in front of the notch
dragnonu's avatar
dragnonu
yeah i lay frame and my control arms are bout 2 and a half inchs off the ground for awesome clearance and the body lays hard as hell to check out my pics in my profile to see it layin not followin you on what you notched?
dragnonu's avatar
dragnonu
mine lays frame and body i built a frame from the firewall back had to drop the frame down bout 5 inchs where it would lay and not the control arms i didnt raise my uppers though but i got djm uppers and lowers and had to notch out the frame in the front where the tie rods would go up in it and not hit will try to have some pics posted on my profile of my frame by this weekend
DawgsledMazda's avatar
DawgsledMazda
read the other posts on laying the 98 up ranger on this forum. theres interesting info on moving control arms. they must be aligned properly to work.
