broke off header bolt
N
blackrado
i went to put a bolt in my header and one was broke off in the hole. any advise on gettin it out??? dont wanna pull the head
cruisinlowS10
do you have a set of easy outs?
lyinlow's avatar
lyinlow
Edited: 10/5/2005 7:06:23 PM by lyinlow
if you can try and grind the bolt flat... get a Center drill and center drill it.. after that then get a drill and drill a hole in the middle.. after that get a easy out as stated above.. if it does not come out this way you can try just drilling it out by stepping up the drills one at a time until you can just pull the remains of the bolt out.. if you do have to go drillin it all the way out BE CAREFul not to ruin the threads!
last resort is if its not broken in there too deep and you can get at it you can weld another bolt on it and then just use a socket on the new bolt to try and spin the broken piece out
hope this helps
Trevor
blackrado
whats easy out?? im no mechanic
Tucking20s
heat it up after using some PB Blaster (red and yellow can) and use an e-z out. If you don't have one then spen 10 dollars on the orileys ones. They'll get the job done.
Tucking20s
its a reverse helix stud with a square end.you drill a pilot hole hammer it in and then lefty loosey the e-z out and it bites and turns it out.
dragontoy22r's avatar
dragontoy22r
Sears carries another easy-out socket style...it fits over broken bolts or stripped nuts, comes right out. Looks like the impeller on a pump.
blackrado
the thing is the bolt wasnt just broke at the head its on down in the hole
