Toyota Trucks \  how tall is a toyota drop spindle?
Toyota Trucks Make Specific
views 342
replies 13
following 9
bdroppeddak   +1y
neone know how tall a toyota pickup drop spindle is from bottom of lower balljoint hole to top of upper balljoint hole?
dragginbagged   +1y
What are YOU up to? Hmmmmm????
bdroppeddak   +1y
shhh!!! im doin a 6 lug swap on my toyota
3In2Out   +1y
If you dont have it by tomorrow, Ill pull out my set of drop spindles I just bought and measure em for ya.
johnny5   +1y
its the same as the stock one the only difference is the splindle location. the actual spindle is moved up 2 inches
streetsweeper1   +1y
he's right it's exactly the same! the only difference is the pin height. on a dropped spindle, that piece is moved up on the casting. you should be measuring from upper ball joint to lower ball joint.
3In2Out   +1y
Yeah, I am pretty sure that is understood. What I was saying is I will measure some that I have that arent on the truck and I know where they are, instead of trying to measure the set on the truck.
bdroppeddak   +1y
thanks man. i wont have any for at least a week and im trying to draw somethin up in 1/10th scale so i need that measurement to be exact on my design.
3In2Out   +1y
If I can, Ill try and get it for you before I go out tonight!
