anyone use this for a tank???
crazeflier07
I was looking into using a nitrous bottle for a air tank and I was wondering if anyone has used one before? What needs to be done to get it to work? Better yet, where can I get one and not have to purchase the whole system with it? lol Thanks!
Low_SST's avatar
Low_SST
it could be done but to use an actual nitrous bottle like one fron NOS or Venom would cost you a pretty penny and prolly wouldnt hold much air.
rizz0's avatar
rizz0
i used one for a vw that i bagged and it is true that it doesn't hold much air but it worked. i just had the bottom of the tank tapped out with one 1/2 inch port and ran a dummy braided line that the kit came with. looks cool if your into that fast and furious stuff lol
crazeflier07
not to much into that f&f look but I just think two tanks on the sides of my trunk painted to match my outside would look pretty cool. Thanks for the info!
Low_SST's avatar
Low_SST
you coulg get away with a larger size nitrogen bottle and if you were to buy it you could paint it what ever you like.
BS
beyond static
i have 8.5 gallons under the bed, and a nitrous bottle under my backseat for a little extra storage (2.5gallons or so). My dad had an old billet bottle laying around, so I used it. I just hooked a regular compression fitting into it, and T'd it into my airtank
lo4lyf
how much psi will a nitrous bottle hold?
mobileheath's avatar
mobileheath
the bottles will hold well more than what any compressor you will find will put out....i think they are rated somewhere between like 1500-3000 psi
libtecguy145's avatar
libtecguy145
i used a scuba tank in the bed holds like 5 gallons same effect though
http://memimage.cardomain.net/member_images/10/web/682000-682999/682659_83_full.jpg
NA
not an extreme
u could also use a big rig air tank.
s10
last post by baha +1y
