Page 1 of 3
Dodge Trucks \  95 ram bags and bodydrop
Dodge Trucks Make Specific
views 543
replies 25
following 9
low95xlt   +1y
ok 95 ram ext cab long bed, already lowered 4/6 via djm upper/lowera arms and a flip kit out back, nowto bag the front i need cups( if so from where) and do i need spindles? back i am 4 linkiing so that not a problem but the front is boggling me
1 LoWfUKn RaM   +1y
u dont need spindles if u have arms all u need is some cups . i dont really know wo makes them but every body i know made there own so u might wanna do that
low95xlt   +1y
anything i need to look out for whe ni bd it or bag it ?
cantlooswit22s   +1y
your gas tank needs to leave.trany xmember if you havent replaced already.make your own cups,saves you $$$.
low95xlt   +1y
yea gas tank is gone fuel cell, already have a trans cross memeber, n e 1 have pics of there bag cups?would a pair of cehvy bag cups that are altered work?
lkrayzie   +1y
just make your own, its a shitload cheeper, $50-$75 for some chevy mounts that your goin to cut and modify, fuck that, go to your local steel shop, and get some 4.5" or 5" DOM, and a flat piece of steel, then measure how big you need em, cut it with a chop saw, take that peice of flat steel, cut out a hole the size of your DOM, put 2 holes for the bolts and 1 for air, then boom, you have a bag bracket that you made for like 20 or something. if you want, you could always order some laser cut plates too for the bottom, but plasma cutter works fine.
lkrayzie   +1y
oh yea, you have have to weld a bolt on the cup too, to hold it in place, ive never done a dodge before, so im not sure
1 LoWfUKn RaM   +1y
no just leave ur cups floating the wont come out u dont need 4 1/2 dom it can be wad ever pipe 3/16 thick at least but it has to be 4 1/2 inches or 5 u can mae ur cups for about 30-40 bucks thats with lazer cut brakets for holes and air fitting
Low_SST   +1y
my cups were made from 5" schedule 40 pipe which has a od of 5.5" i called innovative air suspension and bought some pipe and bag mount plates from him and cut them up and welded em. your gonna have binding issues with the djm arms because they max out the upper balljoints during their travel.
low95xlt   +1y
anything i can do to limit or get rid of this problem?
