one of my boys have a 90 accord 4 door...the back cylinders are fine but the front has a serious rubbing problem. does anyone know how to fix this? the arm rubbing it is got a peice of metal coming out diggin into the can. is there any kinda swap we can do to keep it from rubbing? any help is appreciated
hey, i dont know if this will help much, but i just bought some air cylenders that came off an accord, and you could notice where the cans had been rubbed pritty hard.. so im guessing its a common thing? good luck
GRIND DOWN THE SPINDLE WHERE ITS RUBBING THE CYLINER. IT LOOKS LIKE THEY ARE AIM CANS, I THINK ITS COMMON. MY OLD SMC CYLINDERS HAD AN OFFSET HOLE IN THE LOWER MOUNT TO KEEP IT TUCKED INWARD MORE, TO PREVENT RUBBING.
I have the same problem but after a while the arm grinds enough out of the can that it clears. I have the same markings on mine but it didn't hurt the can at all.
I USED TO HAVE A 98 ACCORD 4DR WITH THE SAME PORBLEM, I GROUND DOWN AN AREA ON THE KNUCKLE THAT MADE IT CLEAR MAYBE 1/4 DEEP, AND 1 INCH LONG, HOPE THIS HELPS ALITTLE
does he drive side to side a lot? I had a similar problem with my air set up in my beetle, but it was cause I like to hit the side switch into turns on and off the hwy ramp
