Dodge Trucks \  Bagging an 05' Ram
Bagging an 05' Ram
Dodge Trucks Make Specific
views 173
replies 2
following 2
NaviGangsta   +1y
05 Dodge Ram 1/2 ton 4 door
What is all required to lay it out on 22's? Full frame
New tranny xmember im sure.Control arms? Spindles?
with a 22x10 wheel, prolly chrome, will the rearend need narrowed?
rabounce   +1y
frame on a 02+ requires z'in the sub frame 1.5" in turn you can also raise the trans that much with the stock trans x member since it only hangs 1.5 below the frame.
then ditch the stock spring pirches and make some new mounts..
I prefer (MY) ekstensive LCA's with flipped chevy balljoints. lets the subframe lay flat
other then that the gas tank hangs down 2 inch's below the frame rail as well.. people have raised the stock tank mount.. and others ditch em...
NaviGangsta   +1y
when you raise the tranny, do you have to cut up the sheetmetal and raise the tranny cover?
And i have done flipped balljoints on my effie (with custom tubular arms to) so that part should be easy
Thanks for your help
