Interior \  How to..?
How to..?
Interior Q & A
views 171
replies 4
following 5
BaggedC10   +1y
how to paint plastic stock door panels? they have been painted before but it wasnt done by me and its just chipping away so easily.
rollinjunk   +1y
check the threads, there's like 20 about painting interior and door panels.
23520s   +1y
Hey man What i did is go to a ppg paint supplier and ask for a plasctic primer. and then prime over that and then paint. it will turn out smooth with no lines.
chumpchange   +1y
rollinjunk-if you dont know then dont post. he doesnt need you smarting him off like that. poeple like you are killing the forums on this sight.
as for painting door panels or any plastic, sand off the old paint someone didnt prep very well if it is chipping off. sand it off with 120 then wet sand with 320 then 600 hundred. wont hurt to sand with a little greased lightning mixed in your water to get rid of any grease and silicone that may be there. if you want it smooth with know factory ridges then get some high build primer for plastic prime wet sand with 600 and prime again. until it is smooth. wet sand one last time then paint clear and you are ready to go. hope this helps you out.
rollinjunk   +1y
i'm not smarting off peolple should just look back through old forums first and if they can't find what they need then make a new forum
