*911*Engine Missing Out and Sputtering
jinx_piercings@yahoo.com's avatar
jinxhilux's avatar
jinxhilux
so when i take off my motor bogs down and spits and sputters, have brand new plugs, plug wires, distributor. will run great after about 4000rpms but between idle and then it sucks! anyone have similar problems?
no1lowr's avatar
no1lowr
injectors maybe, clean them or replace, sounds like a fuel problem
slammedcivicsi's avatar
slammedcivicsi
Id check Fuel pressure, and such, the other thing is it could be a timing problem, if your timing belt or chain ? Ive seen belts slip a tooth before.
stll2hi's avatar
stll2hi
I had same issues on my 94 years ago. Turned out to be a MAF sensor. Sucked buying a new one.
smctoy's avatar
smctoy
Haved you replaced your fuel filters? Try that if you havent, then check the fuel pressure to make sure that all of your injectors are putting out enough fuel.
jinxhilux's avatar
jinxhilux
oh its getting enough fuel, running rich actually, and timing is perfect.....
