gas leak
gas leak
hydroyota
i have gas leaking out of the charcoal canister when i turn of the truck y is this
holcombe347's avatar
holcombe347
my understanding of the charcoal canister is absorb the fuel vapors that remain from the carb. perhaps there could be and underlying problem causing the fuel to overflow into the vacuum line and fill up your canister? how much fuel leaks? just like a drip here and there or like a steady drip?
hydroyota
it pours out when turned off could i have a line hooked up wrong and its the 22re thanks
kdcgrohl's avatar
kdcgrohl
your vent and return lines are hooked up backwards.
twisted customz's avatar
twisted customz
I second that motion, that is what happened to me. did you remove the lines to the tank for any reason?
onelowyota's avatar
onelowyota
third on that i did that on mine after the frame swap.
hydroyota
i will try that thank
