Got this in an e-mail thought it was funny.
U
upallnite
After every flight, pilots fill out a form called a gripe sheet, whichconveys to the mechanics problems encountered with the aircraft duringthe flight that need repair or correction. The mechanics read and correctthe problem, and then respond in writing on the lower half of the formwhat remedial action was taken, and the pilot reviews the gripe sheetsbefore the next flight.Never let it be said that ground crews and engineers lack a sense ofhumor!Here are some actual logged maintenance complaints and problems assubmitted by Qantas pilots and the solution recorded by maintenanceengineers. (P = the problem logged by the pilot.)(S = the solution and action taken by the engineers.)
P: Left inside main tire almost needs replacement.S: Almost replaced left inside main tire.
P: Test flight OK, except auto-land very rough.S: Auto-land not installed on this aircraft.
P: Something loose in cockpit.S: Something tightened in cockpit.
P: Dead bugs on windshield.S: Live bugs on back-order.
P: Autopilot in altitude-hold mode produces a 200 feet per minute descent.S: Cannot reproduce problem on ground.
P: Evidence of leak on right main landing gear.S: Evidence removed.
P: DME volume unbelievably loud.S: DME volume set to more believable level.
P: Friction locks cause throttle levers to stick.S: That's what they're there for.
P: IFF inoperative.S: IFF always inoperative in OFF mode.
P: Suspected crack in windshield.S: Suspect you're right.
P: Number 3 engine missing.S: Engine found on right wing after brief search. (my favorite)
P: Aircraft handles funny.S: Aircraft warned to straighten up, fly right, and be serious.
P: Target radar hums.S: Reprogrammed target radar with lyrics.
P: Mouse in cockpit.S: Cat installed.
P: Noise coming from under instrument panel. Sounds like a midget poundingon something with a hammer.S: Took hammer away from midget.
9
954chick
lmao....the last one is great.
lowrthnu92's avatar
lowrthnu92
DodgeRT's avatar
DodgeRT
bdydrp214
From that last one looks like Smalls is out of a job now.
dragn168's avatar
dragn168
Edited: 10/17/2005 10:06:47 PM by dragn168
ive tried telling my aircraft to fly straight and be serious but it keeps getting drunk on the weekends.
