cylinder not working
gslow2600i
I have a 94 eclipse with cylinders in the rear I am using smc 3/8's valves and cannot get it to lift under its own power. I am running two 3 gallon tanks and a 145psi switch. It also has a huge fiberglass speaker box with 4 12w3's (aprox. 500lbs) It did go up once on its own but will not anymore. I checked for leaks and found nothing major to cause problems. Any help would be greatly appreciated.
pearldrop's avatar
pearldrop
What size cylinders are they?
gslow2600i
3" is what was in the kit
Sickcivic
did u check the lines running to the cylinders.........oh and what kinda cylinders are they???
pearldrop's avatar
pearldrop
Try bumping up the pressure some. I have 3.5s in the back of my wagon and it will barely lift it with one sub and a full tank of gas.
purpl7duece
Maybe a hose is pinched.
gslow2600i
they are are from the devil (AIM). I thought about bumping up the pressure. I think I have a 170 laying around. Also th e way I have my tanks is one feeding the other not teed after the compressor and on tank hooked to the front valves and one tank plumbed to the rear.
s10
last post by baha +1y
