crazy vibration
cris@gravity-werx.com's avatar
crazy vibration
bdroppeddak's avatar
bdroppeddak
i was shoppin around for a beater, and came across a sweet pontiac grandam 4cyl and for some reason the beast has some hard vibrations when it is idle, in gear or out of gear. mean anything like its gonna crap out in the near future?
ID
I drag
yes it has a miss fire but at higher rpm's its just less noticeable might last you but who knows how long
bdroppeddak
hm... so maybe a tune up would help?
deflaytedwayz2
another thing, i duno if this particular car has it but there are counter ballance shafts in the engines on some 4cylnder engines, and its run on the timing belt. maybe someone put on a new belt and got the ballance shaft out of time? just a thought to look into
RAKilla's avatar
RAKilla
Come on Chris tell me your gonna bodydrop it and put some spinners and a V8 in it.
myslamed94s10
what yea is it does it have fuel injiction i check the ingition system first and find out what cylcder is missing and check pulg,then wire if thoes are good i check comperstion if it not miss fireing on any cyclender then i will most likely be you idail air control valve let me know waht you find out
bgp1mpin
DID YOU CHECK ALL OF THE MOTORMOUNTS
TD
the dirty 10
that would be a busted motor mount!
