Air Ride Suspensions \  can you do this to a 2 link?
Air Ride Suspensions Q & A
views 244
replies 12
following 12
bill brasky   +1y
I was wandering if you could run these bars to the back and put the bags on them for more lift on a standard 2 link. Im guessn pobably not since the axle is bolted to the 2 link but Im dumb so tell me what you think
ExplicitDesignz   +1y
Sure. Why not?
Severed701   +1y
yeah u just need to make sure the rear bars has the extra small bar connecting it to the rear end or else it will work against the front bars
FXDGRND   +1y
Cantilever bag setups can work on 4 or 2 links. Just make sure the shackles are long enough so they do not bind on lift or lowering.
bdroppeddak   +1y
why dont you just mount the bag on the 2 link if you are gonna do a 2 link?
mindlissmetalfab   +1y
if u have the skills to add the proper pivots and mounts for the rear LEVER bars (ITS NOT A CANTILEVER), then why not just build a 4 link?
bill brasky   +1y
No 4 link cuz of space it is on an expy and Wanted to keep the floor as factory as possible
parallel 4 with a panhard??
alienwerks03   +1y
if im reading your question right, you wanna run your 2 link bars behind the rear end? you can't do this, it'll throw your pinion angle off drastically and it'll try to pull your drive shaft out of the tranny. just 4 link it!
wht01ranger   +1y
nah, he running 2link forward, with the 2 rear bars with a double pivot on one end for lift
