Bag on bar mounting question
Twotipped@aol.com's avatar
Low_SST's avatar
Low_SST
I just wanted to get an idea as to where i should mount my bag on my bar. I know the closer to the pivot point i go the higher the lift will be but i just wanted opinions of how far back it should be from the pivot point?
1 LoWfUKn RaM's avatar
1 LoWfUKn RaM
8 inches away from that will give u pretty good lift thats wad mine was set up before
F
fatnutz69
i personally wouldnt go any closer to the frame than half of the distance from the center of the bar. in other words the center might be ok but if you can i would recommend a little further out than center. keep in mind drive shaft lenghts and pinion angle. good luck beau
1 LoWfUKn RaM
keep in mind ur tire might rub the bag if too far back too
Low_SST's avatar
Low_SST
yea abe i think im gonna get the diameter of a 24" wheel and tire package and add the difference to my 20s so i know ill have enough clearence if i go as big as 24s in the future. I believe with tires the diameter will be like 33.5" so i would have to be at least 17" plus the diameter of the bag away to make sure ill clear the tires. I guess that means since my bars are like 29" long i can mount the bag like a foot back from the pivot point at max.
kaoss's avatar
kaoss
also pay attention to how high or low you put your bag in relation to the bar. Make sure the frame doesn't hit the ground way before the bag even gets close the flat.
Low_SST's avatar
Low_SST
thats just gonna be a matter of location of upper bag mount, im gonna make a 3.25" spacer and use that to get a refrence to mount my bags to optimize lift.
kaoss's avatar
kaoss
great idea, which I knew to do, I just was so busy measuring everything else, i Faqued up and only get 7" of lift. I'll fix it though.
lkrayzie's avatar
lkrayzie
also rememeber the closer to the pivit point the bags are, the more weight they are holding
Low_SST's avatar
Low_SST
Well ill be running the rs72 slams so i think they can take some weight. Ill try to track down the formula to calculate load at different points on a lever.
s10
last post by baha +1y
