Toyota Trucks \  cleaning up 22R engine bay
Toyota Trucks Make Specific
views 2403
replies 13
following 13
Bentlay   +1y
On the passenger side of the 22r(possibly the RE) theres emmissions crap that 'clutters' up that area. What did you all do to clean it up a little bit? I was lookin through the profiles, but not many engine pix..
Bentlay   +1y
anyone?
HotRodDime   +1y
ditch it all!!! If smog permits Cali sucks!!!
streetsweeper1   +1y
bodydrops and smog in california it was too good to be true...
dragontoy22r   +1y
Don't throw it away or you'll kick your own ass later, but....take all the emissions stuff out. The charcoal canister and hoses can go, if you lenghten the wires to the fuse box, you can tuck that away. I may have pics on the web somewhere...check yahoo "toyota minitrucks group" photos area....maybe?! I even got rid of my AC and heating to get rid of those hoses too.
lkrayzie   +1y
get a weber if its a 22r, then move your fuse box in the cab, relocate your battery in your bed, or under, move your coil and power steering "canister" to your core support, thast waht i did on my 88, before the front got torn off pretty much
truck action   +1y
Charcoal canister under bed,against frame r/h side rear,fuse box mounted to the side of inner fender r/h, battery to inside cab,used a disbution block mounted on top of inner fender for power leads from battery
Iownissan   +1y
...and i thought i was the only one to ever put a battery inside a cab lol
oldsklminitrk   +1y
Honestly I dont remeber but you can remove everything on a factory carb.I got ride of all the charcoal canisters and all of it.....Lemme see if I have some older pics when I ran the factory carb with no emmisions.....but be warned gas mileage you will notice a difference.
the501clique   +1y
just rip as much of it as you can off my truck hasnt passed emmissions since 2000 the numbers on the old sticker just faded off. i only really drive it to shows now though so its not even worth gettin it done havent got one ticket yet. and how do none of you guys have a shop that can hook you up with an inspection.
