clutch problems
clutch problems
low_toyota92
on my 92 we put the cluth cylinder on the inside, everything has been workin fine for bout a year!! But now all it takes to start rollin is just let out just a little bit, i adjusted the pedal but no big help...... maybe air in the line?? any help would be great..... its embarassing as hell to hit switches at a stop light then choke it off ha ha thanks...
Yeah it kinda sounds like air in the line to me, but I could be wrong. Is the resevoir empty?
Forgot to ask to do you hear any noises when you have the clutch pressed in that go away when you release it?
low_toyota92
its got fliud in it and ill have to check and see if i hear any air, just kinda weird that it started out of the blue, but no leaks that i can see
thanks for your help...
