Yota 2.4L 22-RE I4 \  clutch
clutch
views 731
replies 3
tycox   +1y
i put a new clutch master cylinder in and it is not pumping fluid to the slave cylinder. i hooked up the old one and put fluid in it and everything and it pumps the fluid to it. i think its a bad slave cylinder. any thoughts
kdcgrohl   +1y
Did you bench bleed it? Then bleed the entire system from the slave?
nismorgan   +1y
yeah, i just changed both my master and my slave, the key is you HAVE to bench bleed the master before you put it in, or your gonna be sitting there bleeding the slave all day long.
tycox   +1y
yea i bench bleed it. im thinking it is a bad master cylinder i am going to return it and get a new one and try again
