Fuel injector wiring problem!
1 following
dangorango85@gmail.com's avatar
loyota94's avatar
loyota94
I have a 94 Yota with a 22re. Just got the head back together and it wont start. Found the injectors aren't pumping gas, but the fuel pump is working. Checked the wires, and there not getting power. Checked all the wires and connectors all are in good shape.
No cuts, nothing broken, and all run in the factory wiring harness. Why would this be?
loyota94's avatar
loyota94
Figured it out. Just in case anyone else has this problem there are two switches on the theromstat housing. One is a timing switch for the cold start injector. The other is a thermo timing switch. Mine were broken.
