FBI 4 LINK
V
FBI 4 LINK
g&k_customz
whats up guys i have an fbi 4 link with bags over the axle,well iam bodydropping it and want more lift,so iam putting my slams on the bars.do you guys think my fbi bars will hole up?or sld i get some from jason? lata
overkillfabshop's avatar
overkillfabshop
unless fbi has redesigned there 4 link i wouldnt use it.... only thing i would have used there 4 link is on a gocart..
outlawcrewcab's avatar
outlawcrewcab
ya there bars are weak. if you are going to mount the bag on the bars you will need much stronger bars
bdroppeddak's avatar
bdroppeddak
if you are gonna install their cheapest 4 link, make sure you arent gonna drive it much, i remember checkin out their tech article which said to drill a hole in the frame and put a bolt through it for the lower bar front mount
AVTekk's avatar
AVTekk
you wont be able to run the bags on the bars unless you weld a serious plate gusset to the bottom of them.
pootytang
you could get the ssd under bar gussets
outlawcrewcab
even with a gusset i wouldnt on there bars.
lowdyme's avatar
lowdyme
i have the fbi 4 link with my bags on the bars i put a 1/4 in peice of steel under then for a gusset and i have been on it for about a year no problems yet
g&k_customz
thanks for the input guys,an ya cris i hardly ever drive it but i might just get 2 new bars or just gusset under it thanks lata
bdroppeddak
the thing is that they use cheap heim joints, the bars arent all that weak. id try to stay away from a double adjustable end bar if you are gonna mount the bag on it. and for a couple bucks more you can get a better 4 link that uses poly bushings from other companies, hell gravity-werx.com has a nice kit for 250.
s10
last post by baha +1y
