Juice Guru's
explicitdesignz@aol.com's avatar
Juice Guru's
ExplicitDesignz's avatar
ExplicitDesignz
Just finishing up my hydro setup and I ended up having to replace a shaft seal earlier this morning. Get it all together and it started to f**k up again. When I hit it up, the motor just spins. I ran it for a second and then it started to sound like it was binding and some smoke came out. But one cylinder did jump up when I hit it up, but no lift. I`m done screwing wit it for tonight. But tomorrow I`ll take it apart again n check it out. Any ideas fellas???
fkntukn1's avatar
fkntukn1
sounds too me like yer catching a runaway, where yer motor keeps running. if you let it run u will blow the motor. u just have too unhook the batters and hook em up agion and it should fix it.
stcaddad's avatar
stcaddad
check valves in backwords? coupler broken? the smoke could be from oil in the motor if you had to mutch oil in it it will ruin the motor
the501clique
im not sure if im hearing the problem right but it sounds like the key that connects the motor shaft to the shaft on the pumphead isnt the right size
PimpinMidgets
REMEMBER DONT SHARE NEEDLES
ExplicitDesignz
Alright I got it all figured out. It ended up being alot of oil in the motor that I missed. And the smoke was the oil burning in it. But this damn block, I think, is the problem. Still have a small leak. So I`ll be replacing it soon. But all in all, I`m lovin the juice!!
s10
last post by baha +1y
