88 chevy 1500 lowering rear
perry5223@hotmail.com's avatar
chumpchange's avatar
chumpchange
i have an 88 chevy 1500 just wondering if you can flip the bracket that holds the leaf springs in place to the bottom of the axle and then move the leafs to the bottom to lower the back? i know they make flip kits but why couldnt you use the factory shit to do it?
tealchevy's avatar
tealchevy
you would have to grind the bracket that is welded to the tube off and put it on top and reweld.
tealchevy's avatar
tealchevy
make sure when you reweld that you set your pinion angle correctly.
idrgbdy's avatar
idrgbdy
get a 4link and bag it!
chumpchange
4 link and bags is coming but not until i finish my taco. that is what i thought i know about the pinion angle and stuff i was just wondering if that would work. i couldnt see why not so i will do it and drop this bitch.
bgp1mpin
IT WORKS BUT MAKE SURE YOUR DRIVE SHAFT DOESNT GO TOO FAR INTO YOUR TRANSMISSION THE FLIP KITS YOU BUY ADJUST THE AXLE BACK A LITTLE FOR THAT REASON. I MADE MY OWN FOR MY SUBURBAN AND I ENDED UP HAVING TO SHORTEN MY DRIVESHAFT
s10
last post by baha +1y
