link bars instead of radius arms
busdriver
is it possible and would it work to replace the radius arms.
busdriver
anyone
busdriver
pivot from both ends almost like a 4 link
BAGGED 68 FORD's avatar
BAGGED 68 FORD
Yes it is possible. I saw a guy build a 4 link with heim joins to replace his radius arm. It looked and worked good. on a 88 ranger
busdriver
you wouldnt happen to have pics or know the his name
BAGGED 68 FORD
I dont have pics this was 12 years ago.His name is mike. He has a 88 ranger navy blue
extra cab long bed on hydros, the cab tilt's
forward with some long ass hydrolics and he can drive it that way.It's like a Trnsformer.
olskoolpup
ive seen it where the new radius arm has a bushing rod end where it bolts to the frame, but it was still solid mount to the ibeam
BAGGED 68 FORD
All that needs to be done is 2 bolts that go on the frame to one end of the link bar and some tabs on top and on the bottom of the I beam to mount the other end of the link bar. you will need to space out the link bars 1/2 to 1 inch just so that they don't rub on your frame.
bodydropped85's avatar
bodydropped85
easiest way is to put some heims on the end of hte radius arm.
slammedxonair's avatar
slammedxonair
i got my bags on the radius arms hit me up on aim if u need info
s10
last post by baha +1y
