front bags on a s-10
johnboyon20s@yahoo.com's avatar
johnboyon20s's avatar
johnboyon20s
i have bagged a s-10 before with 2600lb bags in the front,i have 4 slamm 72s i was wondering if anybody has put 72s on the front of an s-10 or do yall think it might rub?im just tryin to figure out if i need to sale 2 bags and get smaller ones or if i can make it work with out future problems?
bdroppeddak's avatar
bdroppeddak
Edited: 10/29/2005 3:32:42 AM by bdroppeddak
well the 72 series of slams are smaller than a firestone 224c (2600lb) so you will have no problemos.
badcoma's avatar
badcoma
yea i have bagged 2 different s-10's with rs 72's all you beed to do is cut a little more around the spring pocket and they fit fine
kartracr
If you can fit a 2600 lb bag in the opening You will have no problem fitting any 7 series slam bag. the 2600lb bags will expand in diameter, where the slam bag wont.
johnboyon20s
i thought slamms were bigger around then firestone, but thanks u guys for the info
AVTekk's avatar
AVTekk
you will need to 'eyebrow' the spring pocket like you would with a 2600, no big deal.
panshs10
Edited: 11/4/2005 10:58:41 AM by panshs10
Edited: 11/4/2005 10:58:04 AM by panshs10
Edited: 11/4/2005 10:57:51 AM by panshs10
you still have to trim where the spring pocket is in order for the bag not to rub.:WELD:
9
98lows10
there is a post just like this from not but a week ago.
yea, the 72s will fit fine, i have em up front in my s10. i offset the upper cup 3/4 to the outside, cup the pocket as well as heated it, then flared it.
s10
last post by baha +1y
