Steering wheel removal
draggin97@yahoo.com's avatar
draggin97's avatar
draggin97
Looking to remove the factory steering wheel out of my 98 dually and replace it with a billet wheel. It doesn't have the airbag so do I just remove the center bolt and pull it out? Or do I need a steeing wheel remover? Thanks
chumpchange's avatar
chumpchange
remove the center nut and rock it back and forth it will come off. here's a tip leave the center nut on a couple threads so when it does come loose it doesnt smack you in the face.
kustomcreationz
Sometime with big arms and a lot of patience it'll work great...but it'll be a whole lot easier with a steering wheel puller...and they're not too expensive.
Hope this helps a bit
anothers10
you can get a steering wheel puller for under $10. it will make life easy.
200bodydroppedrangr
how do you remove one with an air bag. isnt there something about it keeps power for awhile even if you take out the battery. thxs.
1SIC84's avatar
1SIC84
you can go to Auto Zone and rent a removal tool.you just have to put a deposit down and they give your cash back when they get there tool back.
