What Rack for RHD?
11 following
corkin_1@hotmail.com's avatar
What Rack for RHD?
impulse's avatar
impulse
What rack would be best to use for RHD in my 87 b2200??
im guessing a 2wd taco rack would be good, but what year?
tofnlows10's avatar
tofnlows10
any rack that comes off a car that was behind the front cross member....and just flip it around.....
or mail jeep..
impulse's avatar
impulse
or mail jeep..
Any examples? how bout the width?
tofnlows10's avatar
tofnlows10
mike from barnyard (i think) has a tacoma rack w/ a gm steering pump.....not sure what year...hit him up he'll help ya out
impulse's avatar
impulse
Last i talked to mike he couldn't remember what year stuff he was using.
mullet
also.. what would be involved for using a manual rack? bump power steering.
Mike
2lowtoy
I used a man rack off of a 98 tercel and narrowed it to my specs . cause I could not find a manule rack from a tacoma 95.5 up. That is what I wanted to use. But the tercel rack worked just fine. Just go to the junk yard find something that is not smashed in the front and is mounted behind the front suppension that way when you flip it to the front it turns normal and works perfect.
DawgsledMazda's avatar
DawgsledMazda
I used a Tacoma rack, it works fine. its a little wider than it needs to be as far as the knuckles in the rack go.
the knuckles on the rack(the part with the accordian boot) needs to be in line with the upper and lower control arm bushings.
this is the most important measurement.
impulse's avatar
impulse
are you using the stock steering pump afterwards or a different one... if so which??
impulse's avatar
impulse
Anyone else with any info?
