compressor leaking back through
MrLarryDouglas@hotmail.com's avatar
95FullSiZE's avatar
95FullSiZE
i have a thomas compressor and its leaking air back through really bad it will build like 80psi then its just starts leaking it all back out whats wrong? can i fix it?
CLNSHVNnDRAGGN's avatar
CLNSHVNnDRAGGN
you need a check valve
baggd91chev
sounds like u have worn ur ring down that happened to my friends
E
ebman
If a check valve won't fix it, the compressor needs rebuilt or replaced.
whynotfab's avatar
whynotfab
All 4 of my Thomas compressors started doing the same, Just use a check valve. The SMC ones are great, let me know if you don't find one somewhere else.
john trevino's avatar
john trevino
smc has good check valves there like 20 bucks from suicide doors or street beat customs has push in check valves that look like unions. but i would get a new compressor anyways only because its only going to get worse.
95FullSiZE's avatar
95FullSiZE
ok thanks guys i was just needing it to hold up for a month or two ima get a AZ when i get the cash.
bodydropped85's avatar
bodydropped85
what compressor is it? i had a 315 and the head cracked. the reed valve could be bad to.
gravity matt's avatar
gravity matt
we have both parker and smc check valves. the smc is a diaphram check valve and after time might need to be rebuilt. a parker is all brass, wont crack and is a ball check. never hardly ever goes bad. i have them in 1/8" as well if that is how small your compressor is.
95FullSiZE's avatar
95FullSiZE
yeah its a thomas 315 how do you use check valves?
s10
last post by baha +1y
