valve not working
fordOndubs@gmail.com's avatar
valve not working
2LOW4U's avatar
2LOW4U
Ok i was on my way home today and lowered the left front side down some, i went to pick it back up later and when i hit the switch all of my gauges move or flicker but the bag doesnt lift up. It will still drop so it is only the fill valve, all of the other valves are still working fine. It is a gc 450 if that helps. What could it be?
cantlooswit22s's avatar
cantlooswit22s
check the the nut on the top,see if its tight.
lownoma99's avatar
lownoma99
check the ground for the valve. also, check the switch itself.
john trevino's avatar
john trevino
you got the answer check it for grd or power and if they both are fine check the switch.
toadfrog17's avatar
toadfrog17
That's GC for you. I had to tear them apart and lube them up with some graphite and then they started working.
2LOW4U's avatar
2LOW4U
ok i went outside to check it and didnt find anything, the nut was tight on top so i hit the switch again and it worked fine like nothing was ever wrong. What does this mean? Is there anyway to make sure this doesnt happen again
HS
hybrid showoff
take the valve apart and lube it with some spray lubricant. make sure all the wires are solidly grounded and connected.
forbidden's avatar
forbidden
sounds like maybe a wire is not connected good... Check them out
s10
last post by baha +1y
