weldable primer
weldable primer
Low_SST avatar
Low_SST
i just was wundering what you guys are using for a weldable primer. very simple question.
FloorVair avatar
FloorVair
Ive used Enviro-Prime 2000 at the shop, only in areas that can be reached from the back side. When i can reach it, i dont use anything, i just coat the backside with POR-15.
bdroppeddak avatar
bdroppeddak
i used the stuff from 3m, but i dont really get how it works, i sprayed a piece of metal and welded the back of it, and it just flaked away, but i coated my taillight fillers and that area of the bed before i welded it anyways.
SoLow03 avatar
SoLow03
3M's 5917. Good product, but like mentioned above, not really sure how it works. Guess it forms a chemical bond when welded that allows the other stuff to flake off.
Chris
ppyota avatar
ppyota
3M is good stuff
Low_SST avatar
Low_SST
well what ive been doing and im not sure how well it works but anyways....i use the iron oxide primer and lay it on really heavy on the backside of filler plates and shit. I know its gonna burn off somewhat but hopefully it works well enough. I didnt know if there was a better thing to use or not.
Severed701 avatar
Severed701
the 3m stuff is good if you can get more than 2 sprays out of a can..for some reason they NEVER work...BUT i found that NAPA sells a much BIGGER can than 3ms..its also cheaper and u can spray the whole thing til empty unlike the 3m..and it appears to be the exact same shit
KEEF avatar
KEEF
mooneyes1 avatar
mooneyes1
i agree with trevor about the 3m stuff clogging ,not only that it cost about 3 times what other comparable products costs my shop is using wurth weld thru now
bodydropped85 avatar
bodydropped85
welded ti then por 15 it, get high off the fumes and pretend you know what your doing lol
