TRUCK WONT START
slammed1990@hotmail.com's avatar
TRUCK WONT START
mr.safety's avatar
mr.safety
ive been helping my brother build his 01 s10 single cab 5 peed we put in a fuel cell and thats reallt the only major mod done to it and now it wont start it has no spark and all fuses are good any ideas? also we've lost the passenger airbag on off switch i dont know if that matters. oh btw its a 2.2L
LM
lowboy msports
is the wiring harness grounded at the back of the frame?
LM
lowboy msports
that is assuming you took the bed off to get to the pump instead of droping the tank.
mr.safety's avatar
mr.safety
yes we did and i made sure to grind all the pain off the frame to ensure a good ground
slammed97dime
If your sure its no spark check the coil pack if not tkae the plug wires off one by one and try and start it to see if they are sparking there is also a fuel pump relay i nteh glove box its the one all teh way left it will not start if that relay is bad i had a lot of problems when i changed my fuel pump the first time with that relay the middle one is the horn just switch them around and see if that works
CD
clutch dust
turn the key...
DizzyDong
i may have the same problem, except i haven't replaced the fuel pump. in the morning my engine cranks and runs but then loses gas and stalls. the engine then cranks but doesn't turn over. i put in new plugs, distributor cap and rotor and took it to chevy for a recall (install foam sleave on distributor) - Note: this was before the engine trouble. has anyone had this problem and if so is it the fuel pump or the distributor?? i have a new AC Delco pump and OEM distributor but not the time to do it myself. thanks guys.
toofvw24's avatar
toofvw24
try the i think it called your emc fuse it the fuse that goes to the fuel pump and it will shut it down
IMMORTALTRUCKS's avatar
IMMORTALTRUCKS
Did you check the module it may not be good.
It is in the distributor
