wiring diagram
wiring diagram
red94toyota
im looking for a wiring diagram so i can install an aftermarket head unit in my friends 96 cavalier thanks for any help you can give me
msturg's avatar
msturg
save yourself the trouble and those installers that follow you, use an adapter. They are like 5 bucks from autozone, then it will be color to color. If you get it from circuit city or just a metra harness it's going to be an 1858.
Have fun with the 15 7mm bolts holding the dash on. Half the time you also get to cut out part of the dash in order to even fit the radio in.
red94toyota
ok will do thank for your help
I
ir8st8
Constant 12V+ Orange
Switched 12V+ Yellow
Ground Black
Illumination Gray
Dimmer Brown
Antenna Trigger Pink
Antenna Right Front
Front Speakers 4" x 6" Doors
Left Front (+) Tan
Left Front (-) Gray
Right Front (+) Light Green
Right Front (-) Dark Green
Rear Speakers 6" x 9" Rear Deck
Left Rear (+) Brown
Left Rear (-) Yellow
Right Rear (+) Dark Blue
Right Rear (-) Light Blue
