EFI fuel pump with fuel cell
I
Idragit
I got a 4.3 efi in an 02 silverado..what fuel pump is everyone runnin? What psi does the system have to have to run an EFI system? 15 psi? ,more or less? Would it be better/ cheaper to get a fuel cell built that will house the factory fuel pump and guage? Anyone knopw how to wire the fuel guage? thanks
mobileheath's avatar
mobileheath
truck idles at 58psi
bodydropped85's avatar
bodydropped85
msd makes pump for efi. up to 120 psi its like 68 bux. usin it on my buddies ranger and it works good. http://store.summitracing.com/partdetail.asp?autofilter=1&Ntt=msd+fuel+pump&N=0&part=MSD%2D2225&autoview=sku&Ntk=KeywordSearch
I
Idragit
how about the fuel guage? ..that fuel pump sounds like the way to go..thanks
toreadorxlt
get a 0-90 ohm sender with your fuel cell. The fuel pump i run on my 4.3L is a ford E2000 external. Can be had at any advance auto for like $75 under the name Master E2000. Just make sure you mount it close and downhill from your fuel cell because the pump is a pusher and not a puller.
toreadorxlt
It was on late 80's and early 90's Fullsize fords. Works good, and you can clamp fuel hose right on it with high pressure line and clamps.
