air problem
air problem
canadianranger28 avatar
canadianranger28
I need help with my ranger.. when I air out my truck over night,,, or if I let the air out all the way for more then an hour,,,,,,right front and right rear side air back up on it's own..I was told that i might have a some kind of internal air leak, but what do you guys think about that..sometimes is just a back and sometimes just that one side.. never left side.. I have toggle swtches. thanks guys
laydout01 avatar
laydout01
got to be an airleak check your valves
Sigon avatar
Sigon
It means that one of your fill valves is probably leaking. Therefore when your bags have zero pressure and the tank has pressure is bleeds through the valve and into the bag. I know this because I have one leaky fill valve right now I need to change.
Here is a way to test it. Completely empty your vales and tank. Zero PSI, if you have a bottle turn your bottle on, if you have a compressor start the truck and the compressor will kick on and as the pressure builds it will lift that corner. If that is the case then you know if is a leaky fill valve.
22dragn avatar
22dragn
bad diaphram, just take apart the valve clean it and if that doesn't work get a new diaphram. i had two of mine go bad and replaced them and now they are fine
primerd85 avatar
primerd85
your fill valve is stuck open. probably just a little bit.
BLACKMAGICON24S avatar
BLACKMAGICON24S
fill valves go bad and thats what happens, depending on what valves you have, you can take the valves apart, clean them and re-seal them. should work fine.
