Chevy/GMC Trucks \  laying frame on 22s
laying frame on 22s
views 1262
replies 14
following 11
CADIMMY69   +1y
I am building a 88 fullsize truck.I have dropped spindles,control arms,bags.bodydroped 4 inches.I have 22s on it and I cant lay frame.I am about 2 inches away from pavement.what can I do to get lower.thanks....
caned96   +1y
whats stoping you firewall, tie rods, lower control arms hitting the frame, frame upper ball joints binding or the bag cups are too big. did you just change from smaller to bigger wheels or has it just never laid.
CADIMMY69   +1y
right now its hitting the upper control arm mounts.should I shave those down has anybody done this.I already cut the frame for the tie-rods.nothing seams to be in the way.
Six15s   +1y
i did one and used djm lower arms fabtec uppers and raised the upper arm mounts 2 inches because of the ball joint angle. it lays body dropped on 22
FluffyFreak   +1y
Charlie am i goin to have to do that even tho my burban isnt bodydropped? i also got 22" and wanna lay frame front to back
kartracr   +1y
4" should lay door. which arms are you using? if there designed to be a drop arm your ball joints may be binding.
http://fabworxcustoms.com/webpics/past/jeff/067.jpg
bshot_98   +1y
I'm going to order some airride control arms will they lay frame on a 96 chevy fullsize with 22. Also I'm about to bodydrop it will these help.
TuKnRaiL   +1y
I have a 97 that lays on 22's with no problem. on mine to get it to lay frame on 22 I had djm uppers and lowers drop spindles and had to notch the control arm and move some items on the driver's firewall.
lo75lux   +1y
my brother is havin to noch the frame for the tie rods and the lower control arms and had to cut the cups b/c they are from AIM and like 8 inches tall. when thats done it will lay frame on 22's with 35 series tires.
hybrid   +1y
is there any way to lay out on 22's with stock arms? im having trouble laying out
