Installing fuel cell in 01 GMC
kenneth@kennethmaris.com's avatar
CHOSN1's avatar
CHOSN1
Anyone know what size line I need and how much? And also is the braided hose worth the money? I bought a fuel cell for my 01 GMC Sierra and will install it in front of the bed. Or, does anyone know a good website on how-to? Thanks
CHOSN1's avatar
CHOSN1
Edited: 11/9/2005 5:56:44 PM by CHOSN1
I have another question. I have a fuel cell with an aftermarket pump inside the tank. I have the flow and return hoses hooked up but my question is on the power. My stock pump sorta looks like this with the black and white connectors
My aftermarket comes with a positive end and a negative end. Each power cable comes with 3 cables. Can i wire all three cables together?
trey
Is the aftermarket pump rated at enough pressure for your fuel injected engine? I had a aluminum cell built for my truck and shortened the stock sending unit/ pump to fit in it. One of the plugs is for the sending unit and the other will be the power for the pump (black I think). I think one wire is hot, one ground and one is for the prime like when you turn the key on and the pump runs for a few seconds then cuts off. Not sure exactly how you should wire it into the other pump though. I woul try ls1tech.com or performancetruck.net on the wiring.
