20"s with 2wd fenders
13 following
V
g&k_customz
hey iam sfbd my 87 ext cab 3 in and am putting 20's on it. is it possible to do with my 2wd fenders beacuse i really don't want to use 4x4 ones,thanks josh
steelnutz91toy's avatar
steelnutz91toy
in you do not put 4x4 finders you will not beable to turn
dragginbagged's avatar
dragginbagged
that comment wasn't necessary
you don't have to use 4wd fenders if you don't want to, just make sure you have the proper offset. keep in mind to be able to actually lay without hitting the fenders you'll need to probably shorten the control arms or narrow the clip. 4wd fenders wouldn't help this. You can check out my profile for ideas on the narrowed clip or NCBIGGJ for a 3" bd on 20s with narrowed control arms, here's his profile:
Http://www.streetsourcemag.com/Profile.aspx?Home=true&ProfileID=14305
bdroppeddak's avatar
bdroppeddak
i had 19s and layed smushed rocker and could turn pretty wide 3" off the ground w/ 2wd fenders.
dragginbagged
^^^^shortened control arms
bdroppeddak
liar!!
maddawg's avatar
maddawg
yes it is possible.
look up the forums "new at this"
and some other ones here regarding 20's for info i posted.
as wayne said proper offset/backspacing is the key.
maddawg's avatar
maddawg
uh..sorry i meant "new to mazdas"
g&k_customz
THANKS GUYS I THOUGHT IT CLD BE DONE AN ALSO I HAVE LOOKED AT THOSE ACCOUNTS SO MANY TIMES I CAN READ THEM OFF IN MY SLEEP YOU GUYS ALL HAVE SOME KICK ASS MAZDAS LATA
maz2low
You can keep your 2wd and lay on 20s with 3inch BD which is what i have . Just get the right offset wheel +45 offset works best
