Toyota Trucks \  taco clutch master
taco clutch master
Toyota Trucks Make Specific
views 297
replies 10
following 7
chumpchange   +1y
I need to raise my clutch master and i understand how it works but the thing i cant grasp is what you do to the bracket that connects to the bottom of the cowl area? do you just section out how much you want to raise it and i have also seen people raise them into the cowl is that necessary? any pics of under the dash would help. also how much do you guys with 18's raise them or recess them?
HIDDEN   +1y
I just use a 1980 4x4 master cylinder and redrilled the 3 holes 2" higher. on the bracket i just drilled the spot welds out and moved it up to line up the holes and welded it back together. fairly simple. mine is very close but dont hit on a 215/35/19 w/ a 3.75" b/d
chumpchange   +1y
do you have any pics? or does anyone have pics of this being done?
GFreeman   +1y
heres how i did mine
chumpchange   +1y
Originally posted by GFreezo
heres how i did mine so what did you have to do under the dash to get it loose adn raise the braket up? and did you have to extend your pedal?
TacoOn20s   +1y
We used one out of a 1990s honda accord and relocated it to under the cowl.
RLK in Camilla did it.
chumpchange   +1y
Originally posted by TacoOn20s
We used one out of a 1990s honda accord and relocated it to under the cowl. you have any pics?RLK in Camilla did it.
doordraggintaco   +1y
OLDER YOTA CYL. WILL BOLT RIGHT UP.ITS ABOUT 1.5 INCHES SHORTER.
time1   +1y
i made mine mount to the floor in the cab. the cylinder and resevoir are gonna be stickin thru the firewall at the bottom next to the frame away from the wheel.
like kelly said, the cylinders out of an 84 yota 4x4 are 1.5 inches shorter!
chumpchange   +1y
yeah i got the smaller cylinder a while back i was just wondering how you guys were raising them up and what you had to do under the dash and if anyone has any good pics of under the dash?
