streetsweeper1
Originally posted by plane jane
first off if you plan on usin a texture bed liner you can get away with more than if you were to paint the bed shiny like the out side of the truck.if you just want to rhino line it after your done then you could get away with just weldin it every half inch or so then seam seal it and shoot your bed coating over it.but if you paint it you will need it to be solid welded.this will take more time and patience.and dont abuse the body filler it is just a light fill not a 5 gallon one.(more money more problems. more mud more problems)what ever you decide to do there are your two ways of goin about it.hope this will help.and dont put body filler over seam sealer.
Agreed NEVER put body filler over seam sealer. There is also no real good reason why you should'nt fill ALL the tack welds. I would never leave gaps when welding sheet together (even if you seal it from the backside). Sheetmetal should always be sealed up all the way. If it's not done the job is not done. Make sure when you weld it up to give the workpiece time to cool between tacks. Also, when grinding sheetmetal it can get too hot also. Make sure to be careful how you hold the grinder on the surface. ALWAYS use the flat part of the flapdisk holding the grinder as flat as you can with the workpiece (this will make the welds grind down more evenly). Also, when you grind for too long in one area the metal will become too hot and can warp. After grinding for too long or from pressing too hard, the metal will turn a dis-colored blue and become more brittle. At this point you should pull off the grinder, and grind on a different area.
