led caddy tails?
mbulszewicz@hotmail.com's avatar
led caddy tails?
libtecguy145's avatar
libtecguy145
ok so i bought the clear L.E.D. caddis from cando and i cant get them to work properly. i have the 3 wire harness. any one who has them on an s-10 if they could tell me what wires to connect to what? the harness has a yellow, white, and brown.on the truckthe driverside has brown, yellow, black and the pass. black, green, brown.
i swear ive tried every combonation and i can only get them to work as brake lights/taillights
libtecguy145
bump
chumpchange's avatar
chumpchange
i believe you need the led module that they sale if you call steve up he can tell you.
libtecguy145
i have the module, the 3 wire one, i need to know what colors to connect to what colors
chevygurly's avatar
chevygurly
are you tapping into the actual harness behind the bulb or the harness under the truck??? if you are tapping into them behind the blub that is wrong you need to tap into the factory under the truck which is located right behind your rollpan.The colors should be the same as the module,each truck varies...use a test light to test each wire.You should be able to get them to work with no problem if you need more help hit me up...
Lonoma2k's avatar
Lonoma2k
ditto
libtecguy145
sweet, i was tapping them into the harness at the bulbs. ill try them at the other harness thanx!
