metal thickness 4 frame
2low2ryde
i have got my mazda down to the bare frame now and am starting to re build the frame, the stock frame is 1/8" steel, just wanted some opinions on 2" box or 3" and 1/8" or 3/16" want it to be sturdy enough to drive and drag but weight can be a factor too, let me know guys
periportfd
Damn the stock frame is 1/8? Anyway, 2x3 or 2x4 .120 is fine.
periportfd
Oh, and if you plan to drag that brand new frame I'd use blocks or some skid pads....120 won't last you long.
maz duh's avatar
maz duh
You can really use either material when doing frame work. I have used both on stuff I've built and haven't had any problems. The 3/16 doesn't warp as much when you weld it which is a consideration for those individuals without a ton of experiance with this type of work. You certainly do not need to use 1/4 inch, this is just overkill on material trying to make up for a lack of engineering.
U
UNIVERSALAIRSUSPENSI
Everyone that i know uses 1/4 wall for stock floor body drops, now seeing as how its just a lil mazda 3/16 should be fine.
ST Kool Laid's avatar
ST Kool Laid
I would ALWAYS use 1/4 wall tubing on frames.
MS
Mr Scrape
We use 1/4 wall on all our frames. Better safe than sorry.
mindlissmetalfab's avatar
mindlissmetalfab
2x3 3/16 on my blazer. fuckin thing ways a ton.
AVTekk's avatar
AVTekk
i disagree, dont use 1/8" wall. the stock frame maye be 1/8" but its 4 or 5" tall. since youre shrinking the height, increase the wall. 3/16" should be ok but I like to go 1/4" to be safe.
s10
last post by baha +1y
