Painting Temp??
Ashton.harwood3@gmail.com's avatar
Painting Temp??
Ashton's avatar
Ashton
I'm trying to paint my frame and its getting cold outside. Do i need to heat my garage frist before i shoot or what?
will the temp change dring times? or make the paint run? or not shoot right?
any help would be great!
bdydrp18's avatar
bdydrp18
yes it need to be with in a temp for the paint to certain degrees to work right. you can ask and the paint store when you get your paint they will help you out. also make sure that you start heat up the area before you go to paint because the srrface most be warmer to. good luck
bodydropped85's avatar
bodydropped85
yea should be atleast 65...
lowbody's avatar
lowbody
i would try to get it around room temp 72degrees.
N
never2eksessiv
you can get catalyst down to 65 degrees just make sure that the temp on the hardener is close to the temp you are painting in, 72 is the ideal temp to paint in though, goodluck
reaperride1
make sure to heat the vehicle up also , the vehicle temp & paint should be close to the same temp before you start painting.65-75 degrees is sufficient
