Need help with torrisons
13 following
Sitnlow@verizon.net's avatar
sitnlow4life's avatar
sitnlow4life
Please help I tried to lower my truck by lossening the torrions. There are 2 nuts on the bolt for some reason I can nto get either of them loose. I need to break them free to be able to loosen the torrisions Correct? Any Ideas? Suggestions?
Please Help
9
92LOWYOTA
Yeah u are correct there is 2 nuts the only way i was ablt to get them loose was by alot of pb blaster (eats rust) and some heat. And have 2 wrenches have the top going towards loosening and the other towards tighting. and eventually it will come loose
1989dangeroustoy
they are a bitch,i just put 2 wrenches on and faught with them until they cracked loose,try liquid wrench and and impact gun on the bottom of the bolt to loosen them up a little
therealybnrml
mine came loose easy....now getting the bold that they attach to on the control arms out is a bitch
s10soolow
me and my brother took one of with a ratchet and a long bar and the other well it broke the bolt using a impact at his garage it shered the end off his gun and fuck his wrist be carefull with those suckers
whynotfab's avatar
whynotfab
PB Blaster is awesome..
sitnlow4life
One more thing I dropped the back its sitting on a pulled middle leaf and 3in blocks.
I already removed the bump stops and it bottoms on the frame all the time.
I not ready to bag it yet.
Who makes a bolt in C-notch so that I can make the ride a little more tolerable.
Thanks
9
92LOWYOTA
I do not know of any bolt on c notches for a yota. If u are not real comfortable welding one in it should not cost a hole lot to have some one to weld one in.
9
92LOWYOTA
Edited: 11/27/2005 6:31:45 PM by 92LOWYOTA
We have a universal one w/ 2.25 inch more clearence, c&c cut 1/4 plate sell it to u for 59 bucks $10-15 for shipping its on the site
chumpchange's avatar
chumpchange
assuming you do have the front end jacked up and under jack stands try an impact it will eventually come loose.
